- Replies 18
- Views 3k
Scottfunk 4 posts
trreed 4 posts
AH64ID 3 posts
tylertrebilcock 3 posts
It might help some, but it likely won't cover the cost of the upgrade. What trans do you have? Personally I'd go 4.10's, especially if you have an auto.
How did the pattern turn out?. If you took the carrier out easily, that means the original preload was gone. My D80, the carrier fell out of the housing, and when I put it back in, it was so tight t
Im looking into re gearing my truck to accommodate 35s, I’m kind of stuck between 3:73 or just going with 4:10. Is anyone running these setups and how does it do. Also is there an equation to calculate final ratio with the bigger tires? My MPG is like 12 it town and 15 on highway with the quad. I think gearing should fix my problem.
