- Replies 7
- Views 1.8k
Scottfunk 3 posts
Dieselfuture 1 post
sooxies 1 post
tylertrebilcock 1 post
Popular Days
Thanks @sooxies this will be daily reading until I do the gear swap. The rear axle of my truck odd one of the few parts I know for sure will be sticking around indefinitely so I plan to treat it right
Funny I’m doing a 4:10 swap right now, watch eBay for a genuine Dana to pop up if your patient lol I got one for 70 bucks to my door. Dana 70 parts are a little more expensive so I just bought new gen
So I have been experiencing a gnarly vibration coming from somewhere in the drivetrain. The slip yoke into the transmission and the entire driveshaft is brand new so I'm inclined to rule them out. Nevertheless I inspected them and the u joints as I removed them and did not find any slop anywhere. Once I had the driveshaft off I noticed that the pinion had quite a bit of play both in rotation and in-n-out movement.
I decided to tear down the pumpkin just to see what it looks like in there (I'm planning on changing gearsets in the next few months and thought exploring a bit in there couldn't hurt). I noticed the wear pattern seems to be way off toward the heel (outer circumference) of the ring gear and a lack of wear on the toe end of the pinion (see pictures). I've never built an axle before but this wear pattern would seem to confirm that the pinion is too loose and pushing itself out of the ring gear under acceleration and then just kind of wobbling around in there at cruise speeds and making the vibration. Before removing the axle shafts I rotated the carrier back and forth and found that the spider gears visibly moved in and out on their shaft adding even more play as the carrier spins.
Lastly, when I removed the last carrier bearing bolt the whole carrier fell out, plop, and landed right on the sway bar. I have heard stories of people needing case spreaders to get carriers out, so this too seemed odd. I also noted the lack of a crush sleeve or anything to set preload on the pinion.
So my questions are this:
1. How much of this seems odd to me just because I have zero experience in this part of my truck?
2. What are the chances that I'm going to damage something if I goop up the cover, add fresh oil, and run it for another few months?
3. What's the best source of info for setting up the rear end so I can get everything set up properly when I do swap gears?
4. Does anyone have a good 4.10 ring and pinion set for sale?
