Drain plug for auto transmission, where to put it?
I'm going to install a drain plug in the transmission pan of my truck.  I'm going to use the drain plug for my temp gauge also.   Where in the pan is the best place to put it so it doesn't interfere with anything.
Bob
  • Replies 7
  • Views 3.5k
  • Opps just noticed this is in the 12v powertrain forum, is the 47rh pan the same as the 47re.   I also see that both plugs were gas welded in with brass, I must have confused the installation of these
  • 2000Ram2500
    2000Ram2500
    the RH and RE pans are the same. And im even using the deep pan kit for a 727 on my 47RE. The 48 also shares this gasket.   carquest sells a drain plug kit that you dont have to weld in if t
I'm along for the ride with this. I will be doing the same thing next tranny service.
L8tr
D
I cut in half a pipe female to female coupling 1/8 NPT and used a mig to weld it to the front drivers side of the pan, lower part of the pan.  The pan is thick enough metal that you don't need to worry about warping, at least with a mig.  I don't know if this is the best place but it seems to work well for me.
Edited by bcbigfoot
Opps just noticed this is in the 12v powertrain forum, is the 47rh pan the same as the 47re.   I also see that both plugs were gas welded in with brass, I must have confused the installation of these plugs with the one I installed in my Dakota, which was welded in using a mig.
carquest sells a drain plug kit that you dont have to weld in if thats an issue for anyone
Edited by 2000Ram2500
  • 2 months later...
