Drain plug for auto transmission, where to put it?
- Replies 7
- Views 3.4k
Mopar1973Man 2 posts
bcbigfoot 2 posts
98whitelightnin 1 post
2000Ram2500 1 post
Opps just noticed this is in the 12v powertrain forum, is the 47rh pan the same as the 47re. I also see that both plugs were gas welded in with brass, I must have confused the installation of these
the RH and RE pans are the same. And im even using the deep pan kit for a 727 on my 47RE. The 48 also shares this gasket. carquest sells a drain plug kit that you dont have to weld in if t
I'm going to install a drain plug in the transmission pan of my truck. I'm going to use the drain plug for my temp gauge also. Where in the pan is the best place to put it so it doesn't interfere with anything.
Bob
