Poor fuel mileage, dead pedal, CEL on and off
- Replies 22
- Views 3.5k
Jeubank84 7 posts
dripley 6 posts
Dieselfuture 4 posts
Mopar1973Man 2 posts
Where is spell check when you need it?
You need to go through your truck with some dielectric grease on all the multi plugs and cycle them a few times to make sure you get it all over the prongs. Then do the ground mods that everyone has b
Well fingers crossed I may have found the issue. I’m still going to do the ground mod when I get time. I took the air filter out to clean it, and there is a tiny ground behind my afe airbox that was l
Have a 2000 5 speed 24v. Edge juice with attitude, 3.55s, 33” tires with leveling kit, fass150, getting poor mileage and not driving hard at all. Avg 13 hand calculated. Have dead pedal frequently, will last 5-10 sometimes 15 seconds then pedal will come back. CEL came off ran code p0237 low voltage. Checked some grounds, ran great for 2 weeks. Dead pedal came back no CEL. Changed map sensor still no help. Went over grounds again all look good. Truck has new batteries and all new terminals within past 6 months.
