Replacement brake lines from abs and block to frame
- Replies 9
- Views 3.3k
Dieselfuture 2 posts
Bar GN 2 posts
Mopar1973Man 1 post
dripley 1 post
First I have to say MoparMan rocks. Has saved me hundreds if not thousands over the years! I'm looking for suggestions on the hard lines from the ABS controller and aluminum block that run to frame mounted blocks. It appears that Dodge went with a hybrid of standard and metric on the lines. Wanted to se what y'all have done when they rust out. I was blessed that failure occurred on the ranch and not on the road. Is there pre-bent lines available or has anyone used stainless braided for this application. Thanks for any input.
