- Replies 15
- Views 3.5k
JCLOPP 5 posts
Mopar1973Man 4 posts
dripley 2 posts
Marcus2000monster 2 posts
Popular Days
I hope all is well after the hospital stay. It's good to hear you have the truck running tip top again with out a lot of cost. One thing though is that the fuel pressure is way to high. You wan
Fuel pressure? You need to have a gauge in the cab. I'm going to bet the fuel pressure is really low. You need to keep 14 to 20 PSI while at WOT going down the pavement. As for the loss of
I ran a booster bump on mine for quite a while along with the in tank pump. It served me well and fixed some issues with low pressure I had. It did work but I never had much Idea of the pressure nor w
I have an 02 2500 6 SPD manual tranny. Bone stock except cold air intake. Recently truck seems to be losing fuel prime and I can find nowhere it is going. Truck sits overnight and fuel filter housing will be empty causing very hard start problems. When I do get it started seems to idle fine. When I drive it sounds like turbo is not coming in until upper rpm range. Truck will barely pull itself up even the smallest of hills. Lift pump is new (one mounted on engine) and seems to be working fine fills filter housing in under 10 seconds. No DTC codes. Any ideas or suggestions would be greatly appreciated.
