- Replies 55
- Views 12.6k
hawkeye213 18 posts
LiveOak 11 posts
Mopar1973Man 7 posts
AH64ID 7 posts
Will get started on removing the drivelines today. Mopar I was looking at the manufacturers links on your web site and found Standard Transmission and Gear listed. Have you or anybody else here ever done business with them? Found a place out of Memphis called High Gear Transmission also. High Gear had this info
THIS IS A STANDARD SHIFT TRANSMISSION, NV5600 6 SPEED, FOR THE DODGE 3500 SERIES DIESEL TRUCKS.WE HAVE THESE IN 2X4 AND 4X4. THESE UNITS ARE REBUILT, UPDATED AND DYNO TESTED. (MY DYNO TESTER COST $80,000. BEFORE YOU BUY A TRANSMISSION FROM SOMEWHERE ELSE, ASK IF THEY HAVE MADE THAT KIND OF INVESTMENT IN THEIR PRODUCTS.) ALL THIS MEANS THEY WILL WORK WELL FOR YOU WHEN YOU GET THEM. WE DO SEVERAL THINGS TO MAKE THESE TRANSMISSIONS LAST LONGER. ASK US ABOUT IT WHEN YOU CALL.
listed on the tranny Will give them all a call on Monday. Will a 3500 fit my 2500 ?I just found the link to the transmission write up from the dodge forum http://dodgeforum.com/forum/dodge-cu...rk-nv5600.html that will be very helpful. Nice write up by that guy. I also need a clutch. Found a SBC 1947 OFE at TV diesel for 650.00. Does that sound like the right one for me. I don't do a lot of pulling. Haul a cabover to Montana once a year and occassionally pull a load of firewood. Just a few questions. I notice some clutches come with a fly wheel can I just reuse mine or do I need a new one? Is there anything else you would do while you have this tranny out. Rear main seal ? Any other thoughts or suggestions or tips to make this job any easier would be a appreciated.Thanks Rob
