Windshield wiper. Upgrade to faster?
- Replies 34
- Views 7.6k
015point9 11 posts
Mopar1973Man 9 posts
dripley 6 posts
JAG1 4 posts
I've got a solution that is even better. This stuff makes the water bead up and blow off the glass. I typically find that I leave the wipers off more than actually run them. Even the smallest drops wi
Mine were not easy to remove. First time removed since I got it in 2005. Very stiff to pull tab up toward top of windshield. You can see other end of tab at bottom of arm and see unpainted spot on
Heck I'll one up you then... I Armor-All'ed my dash, vacuum the carpet, cleaned the glass, and degreased the engine and transmission. I should be good for another +1 MPG. Eh?
Is there any upgrade to get wipers to go faster?
