  • Replies 34
  • Views 5.7k
    I've got a solution that is even better. This stuff makes the water bead up and blow off the glass. I typically find that I leave the wipers off more than actually run them. Even the smallest drops wi
  • Mine were not easy to remove.  First time removed since I got it in 2005.  Very stiff to pull tab up toward top of windshield.  You can see other end of tab at bottom of arm and see unpainted spot on
    Heck I'll one up you then... I Armor-All'ed my dash, vacuum the carpet, cleaned the glass, and degreased the engine and transmission. I should be good for another +1 MPG. Eh?
49 minutes ago, Mopar1973Man said:
Not really. I would most likely say if the wipers are getting slow most likely the wiper motor is getting worn out.
Ok thanks... wiper motor not running slower than 15 years ago...
But have cowl off right now, so that if upgrade available I'd upgrade.  In pic, does those pivot joints for wipers any grease?  If so what type so do they dont gather dirt/rust.
☠ My bad...after reading manual, says linkage connected with "plastic sleeve-type bushing".  Probably designed to wear out eventually.20180902_172305.jpg.fd6d601771cb9903080122dad0ee532e.jpg
Edited by 015point9
Added info
I'd leave it alone, maybe do something with large holes to keep big things like pick email niddels out. I put some mesh on mine.
Just noticed all that stuff in pic.  That is reflection off windshield of my yard.  Not moss or needles.  Well some moss in yard and It does look like a mess in pic?
Reason for asking about faster wipers is for light drizzle and then constant spray on freeway when most people doing 45, because hard to see.
Also the right squirter nozzle only dripples.  Manual said shoot in some air at nozzle.  Well see if I cleared whatever out.  I think those windshield nozzles are hard to find?  At least not in my LMC book of spring 2012. ( I should call and get newer book).  Didn't find them looking at Dormans either.
I've got a solution that is even better. This stuff makes the water bead up and blow off the glass. I typically find that I leave the wipers off more than actually run them. Even the smallest drops will roll right off the glass. Even in a good downpour most of the water blows off the glass at highway speeds.
Image result for walmart windshield washer fluid
Yeap I use rainx too and it works great. Once in a while I spray a coat on and it usually lasts a while.
I want to pull that cowel/ cover also. How do you go about pulling the wiper arms off without damaging anything? T.I.A.
Wiper arms are easy to remove. Lift the arm up and you'll see a tab at the pivot. Lift this tab away from the pivot which unlocks the head. Now wiggle the head just a little and lift as you go. It will slide right of the splines.
Mine were not easy to remove.  First time removed since I got it in 2005.  Very stiff to pull tab up toward top of windshield.  You can see other end of tab at bottom of arm and see unpainted spot on tab after pulling.  My fingers to big, so I used plyiers.  Right arm that the pivot point is in center of windshield will provide couple yoga exercises for you.  Those little black plastic covers that have a torque head in them unscrew but not truly a threaded nut.  The warning in the manual about screwing it up (posted above) ...I'll find out today if i did.  And going to remove fluid tank and wash out good as something made it's way into nozzle and plugged it up.  Pic in manual not very good imo.  Here is pic that shows better imo.
Never removed mine. Maybe one day I will have to. Hope they are not stuck like the unit bearings.
 The rain ex is good stuff. I have used for decades. It seems to work better for me at night. Sometimes I can't even see drops hitting the windshield before they blow off.
M 80's.
M 80's.
I'm sure I'll pick up at least 1mpg now that all  junk have been removed??.  That's a joke.
Hope I never have to remove it again.
The other trick I know is to use the newer single beam wiper blades. I typically replace wiper blade twice a year in the spring and in the fall. I've used both Bosch and RainX brand wipers. The single beam design tend to get equal pressure across the entire length of wiper blade. I'm pretty sure stock was 19" wiper blades. Most might list them as 20" wiper blade which is a nice upgrade too.
Image result for wiper blades
Two new pdeal pads and a new dash bezel got me 30 more hp!!!!!.
Basic 101 question... when instructions in OEM manual, thats is for gas and our diesel says to "disconnect and isolate the battery negative cable"  can I just disconnect drivers side battery or do both?  I realize playing it safe by doing both sides, but about all elec stuff in manual gives same warning.  Wondering if necessary.
@Dripley is that a bungie cord I see?
Washer reservoir is a PITA to pull. There is two dimples of plastic that you have to use 2 flat blade screwdrivers to get released then you can slide it up off the fan shroud. Then you can clean out your bottle and fix any issues you might have.
@JAG1.  ...
When you get yours apart, would you mind looking at something?
In OEM manual says nothing about "hood to cowl seal-center"
Which is number 1 in LMC pic.
Do you have one?  What does it look like? And what does it do or purpose?
Thanks
LMC truck is correct. There is actually two versions of that seal really. The one you seal where its just a foam rubber seal and then there is a second version that has a conceal flap that hangs down to conceal the wiring along the cowl.
