Airdog elec connection under hood
- Replies 8
- Views 2.3k
JAG1 3 posts
015point9 2 posts
Mopar1973Man 1 post
notlimah 1 post
Popular Days
I put my relay here and ran power for my FASS to the PDC
I used the existing ground screw for both the fuse and relay.
You don't have to run the power from the battery you can tap into the PDC as shown in the article below, You can also use an existing bolt or screw hole for both mounting the relay and a ground point
Where is a good location to install the elec connection for air dog?
In pic... mine is secured by a zip tie and tucked under weatherstriping that goes across the cowl. And not weather tight connection. Certainly must be better spot.
Also,is one battery better than other for connection?
Thanks
