- Replies 27
- Views 11.1k
ruedger455 10 posts
IBMobile 3 posts
Me78569 3 posts
2000Ram2500 3 posts
If that fitting is bound that tight I don't think an easy out will work. With the walls so thin It probably will just jam the threads of the fitting tighter into the case. I would take
Such a relief!!! These are worth their weight in gold!!! Anyone know what this fitting is called and the called? Also this axe body wash is the best grease oil remover I've ever seen.
Go buy a lottery ticket because you got lucky. If you snapped the fitting taking it off I thought for sure that was seized in the case.
Does anyone know where I can get new trans cooler lines from the transmission up to the heat exchanger tank or whatever that tank is on the side of the trans? Its leaking really bad out of that fitting.
