- Replies 20
- Views 3.7k
Blueox01 7 posts
Marcus2000monster 7 posts
dripley 3 posts
Mopar1973Man 2 posts
Popular Days
You really have to make sure Vac pump seal in correct, easy to put in wrong way, from my own experience. been a long time since i did it, but if I remember right it goes in opposite of what you think.
I was apeaking of the "tappet" cover or push rod galley on the side of the engine. It runs from behind the VP to the rear of the block.
Bad description, sorry I don't have a pic of that seal.
A few months ago I noticed a small amount of oil on the ground and traced it to the vacuum pump/ PS pump are and resealed both pumps. Went a while without seeing any more oil until tonight I pulled the truck into the shop and an hr later noticed a 3 in dia puddle. It looks like it is either coming from vacc pump or front main or timing cover. The front half of he truck is plastered with oil which is very disturbing to me. ( no more rust is a + side lol) Cleaned up things good with brake cleaner and we will see what happens. Any idea why the pump would leak again so soon? Look like it’s possibly coming from where the pump mounts to the gear case. Really hoping I don’t have to put a front main or gear case seal on....
