Tranny lunges in gear/odd shifts 40mph max
- Replies 34
- Views 4.5k
CDeGolier2001 18 posts
Mopar1973Man 8 posts
pepsi71ocean 5 posts
2000Ram2500 2 posts
I have a 2001 2500 4x4auto. I recently changed the entire body which was rotted to gas truck body. Went fairly well until I started truck and found out that power steering pump shaft broke? And hydroboost went as well. Fixed both and can steer and stop but now tryed to drive it and when u shift out of park it basically jumps into R or D depends on what u select,seems like brakes almost don't want to hold truck back,try to accelerate and truck moves then slows down then shifts then revs then shifts and 40 is highest it will go will Erving high?please help truck drove beautifully before changing bodies. I'm new to site so please excuse the way I described this problem,thank you
