VP44 diagnostic trail, confirmation needed
- Replies 10
- Views 2.2k
Dieselfuture 3 posts
dripley 2 posts
Cudabuck 2 posts
Mopar1973Man 1 post
Popular Days
Thanks guys..
I've got a bug up my sleeve to put a CR in that body style SRW 350. Black/Tan King Ranch too. Not sure that will ever happen.
Ummm... P0216 code could be... If the timing piston is galled up and damaged there is no real electronic issue with the PSG but the timing piston can be jamming up becaus
Good afternoon everyone, hope you all are doing well. I have a pretty good idea but wanted to get some more opinions on my VP44 issues. I immediately get 0216 and 1693 after I clear the codes and start the truck. Here is the good trail.... It drives just fine unloaded and even pulling when it's cool. but when the heat starts to build, it seems to heat soak and then starts cutting power. The hotter is gets (truck and weather) the worse it does it. I drove it unloaded to work at 4 am this morning, ran like a dream. I never have less that 14 PSI, mostly 15-16 of fuel pressure. Seems to me it's pretty clear the magic computer box on the VP44 is getting hot and crapping out. Anyone have any other ideas, or confident concurrence? Thanks all, have a great day.
