Wierd idle
This has been going on for a long time now. My cold starts are perfect no hesitation fires right off. When I start the truck after work in the evening or whatever when it has been warm I fire it up and have a rough idle for like 10 or 12 seconds. Also accompanied by blue smoke. WhT the heck is the deal? Iv been putting up with it for a while but I worked on a 24 valve at the shop the other day that started and ran way smoother than mine.
  • Replies 47
  • Views 7.6k
  • Mike's pictures show you what to look for.  Valve stem seals are about two hours to replace.  53 blocks are only really an issue if you start it cold and beat the piss out of it before it's warmed up.
  • My guess is you truck is not going to fall a part at the moment. So take breath and be calm.
  • Oil is getting into the combustion chamber.
27 minutes ago, JAG1 said:
I'm curious.... what oil are you using and how many miles on your engine? :popcorn:
Rotella T6 and 133k
And I need more coffee
2 hours ago, trreed said:
@Dieselfuture, I guess I missed why you didn’t go for OEM Cummins seals for the VP head? Can you elaborate on that?
Because when I had the head at machine shop they didn't asked me if I wanted to machine it for newer tophat stile seals, @Marcus2000monster it's $80 extra to do so. Well worth it if you have the head off. So they used seals that came in my Cummins hg set, which blew off and got destroyed by spring retainers. So instead of taking head off again I found the closest match of seals that happened to be Ford. And yes @Marcus2000monster they need out side diameter shaved down, inside of rubber just a bit I have pictures and size of drill bit in my thread, also going in reverse on the drill and not all the way up, and I took little coil springs off the seals so there isn't as much tension on valve.
Edit
@trreed I didn't answer your question directly. But maybe you got what I'm saying.
Originally last year I had an oil Leak from hg, so when I took the head to the shop they did basic rebuild with new guide inserts, valve job, ect. And I had head gasket set that I got from geno's, so I dropped valve seals that came with it off to the shop, which were original Cummins seals. I didn't know about top hats at the time, never ran in to it before. And I didn't have any problems burning oil or smoking from bad seals, the whole reason for taking head off is oil leak. So apparently my shop didn't know any better or didn't think I'll have a problem and used the seals I gave them. Well not even a year later, half of exhaust seals popped up, and that's where I came up with Ford seals for now, and hopefully ever :lmao:and I did this twice as later some intake seals also popped. I was going to use Ford seals on all valves in the beginning to decided to only put them on exhaust side as intakes were fine, well not long after intakes popped too. I want to say it's because of exhaust break pressure. Just can't have shop and then me doing seals and having same results. So we'll see how @Mopar1973Man head holds up, if his will be fine then there is something wrong on my end. I don't think it's boost pressure, I don't go pass 45psi, but like mentioned by other member he hit 70psi of back pressure from using EB.
Edited by Dieselfuture
57 minutes ago, Mopar1973Man said:
I'm working my way on reassembly now. We'll see soon, won't we... :pray:
Hoping all goes well mike.
9 hours ago, Marcus2000monster said:
Rotella T6 and 133k
Eee Gads thats too low a miles to have problems, Never heard of such a thing. Do any you guys think its because they legislated us out of the good ol'e CI-4oils? I've got 200 k on the 01 and 99k on the 02 and neither smoke it up like out in the parking lot in high school.
I'm still using the CI-4 oil which may have something to do with it. :shrug:
I'm still on the CI-4 by the way.
Myself along with my coworker believe it’s not valve stems as well. We are thinking injectors somewhere. Crushes o rings etc. gotta do a reinstall on them and see what happens. Cheap stuff gonna get checked first.
We don't have coffee we got rocket fuel, your welcome to come over for a cup or 3
