VP44 Keyway Dropped into Gear Case
- Replies 49
- Views 13k
Bafazane 12 posts
dripley 11 posts
Mopar1973Man 6 posts
Dieselfuture 6 posts
Yeah, the outside you'll see the oil leak and the crack case typically below the fan mount.
The good news is that I found the key (and installed the new VP44, so that if I knocked that one off too, I wouldn't have to repeat the timing cover removal)! Going to finish cleaning everything up, t
With the cover off this would be a good time to take care of the KDP, Killer Dowel Pin.
Unfortunately, while removing my injection pump, I dropped the keyway into the gear case. I'm going to fish around a bit more to see if I can get it out easily, but I know I'm likely looking at timing gear cover removal. The two things I'm wondering about are:
- Whether or not it's necessary to replace the crank seal while you're in there
- What gasket maker people prefer to use when reinstalling the timing cover
I've searched quite a bit but have not found any solid answers.
What do you guys think?
