- Replies 19
- Views 2.5k
Bullet 7 posts
Me78569 6 posts
dave110 2 posts
Royal Squire 2 posts
Popular Days
I dd'd with ~250 horse injectors and passed emissions with a single he351ve. It's all in the tuning. I ran a quadzilla adr and it was a pleasure to drive. There's videos in the article s
Hahaha...that's good stuff Dave. Outside of the cities in Texas you don't even need a permit to build a house...just build away. Thanks for the compliment and the laugh! Tell me more about t
Pretty sure it is leaking both testosterone and sex appeal "Because Viper" trumps a lot of things . I always wanted the Ford GT, but I can't help but drool over
Hello everyone...this forum is great! Lots of good info and very diesel intelligent people on here.
I have done a lot of mods to my regular cab 2nd gen 4x4...my craziest mod was a shortbed conversion. I bought a half ton donor truck and cut both trucks in half. Moved to back of the half ton over to mine and welded her up. I also used the half ton rear springs...had to cut off and weld new perches onto my axle to accept the 2.5" wide half ton springs. Also used the half ton gas tank converted over to diesel. Cut my driveshaft down along with all brake lines and fuel lines...and supported the frame welds with a 3/8" diamond shaped plate welded across both halves. Took me 2 weeks to complete but it came out perfect.
Also installed long control arms up front with 8" lift coil springs. Then body lifted it 3" which makes it very easy to work on with the extra space between the valve cover and the firewall. It also has twin turbos 62 over 75, a Smarty, a TST PM3 with comp software, a fully built Goerend auto with billet input & intermediate shafts & a triple disc torque converter, headstuds, full gauges, a fuel boss pump, and a 5" stainless exhaust.
I have done all the work myself with the help of forums like this. Very happy to be here!
