Trouble Starting Engine - HELP
MM suggested I post up after speaking with him on the telephone yesterday afternoon.
this all started after some cold weather here. leaving work one day and just died on me a few times, hard to start and then finally nothing.
here goes
working on a 1999 2500 5.9 l . it is hi-line w/auto transmission. key fobs never worked for me.
trouble is it is very very hard to start. finally got it to run yesterday, let it run for about 5 minutes and turned it off. it didn’t want to start again.
then when turning the key to start and run position, no lift pump noise.
i waited 30 minutes and cycled the key again and heard the lift pump running.
wait to start light come on immediately for about 2 seconds then goes off. grid heater are not hooked up at this time
before I have let it run till it warmed and shifted the gears and/or gave it some fuel and just dies.
batteries are at full charge, 13.9v from alternator. I did have the alt. checked. checked out fine. mm suggested to take it out and have it checked again for bad diodes
new rebuilt starter
refreshed/rebuilt ecm
new tpps
IP been in it just at two years (blue chip diesel - stock)
lift pump in it just at 2.5 years (airtex)
have not replaced sealing washers at back of the head. going to do that later today as long as Michael doesn’t dump water on me.
going to get a better fuel pressure gauge today and check that, again. was checking it with a HF pressure testing kit.
all cable ends have been replaced, new military style battery clamps.     have not combined grounds to block, yet.
Edited by RAD
  • Replies 148
  • Views 28.2k
  • Don't feel bad... I can't tell whether its a girl or a guy anymore.
  • I did not know an airtex came ready to plug into the stock pig tail. Or did you make something to do that with? Is set up thru a relay or is the pig tail the power source for the pump? The reason I as
  • Agreed. I was thinking lift pump relay. I believe you meant NOT best for the ECM
3 hours ago, dripley said:
How do you know the pressure dropped if dont have a gauge connected? When I turn mine on you can hear the engine load up bit but the rpm then returns to normal quickly if there is drop. A fuel pressure drop for the AC on should be nil.
I got one and put it on thursday, an in-line type between the fuel filter and IP.
5 hours ago, RAD said:
It’s an airtex e7153
I suggest trying a new one temporarily and then getting a Airdog system. I had an airtex when I bought my truck that failed. I’m lucky I didn’t ruin my VP44
Going to make it a bit difficult to know what pressure is under load. I lost my AD pump a few weeks back and would not have known with out my in cab gauge. Probably would have driven it until the VP burnt up.
I would like to try something to definitely rule out the LP.
i am want to take the airtex apart to look at the workings .
Checking the pressure under load would tell you pretty quick. I suspect you would be lucky to see 5 psi out that pump as much as it dropped free revving.
i cannot even get 50’ without quitting.
Edited by RAD
Then all the restriction of the 6mm ID lines and the banjo bolts don't help it either.
Then if it got a suction air leak as the engine load goes up the air leak will get worse and most likely what is stalling the engine out. When the bubble gets to the lift pump the pressure dies off.
All the more reason for a good fuel system.
It will be well worth the investment to get a new system. When I was at that spot when I needed a lift pump I had a hard time convincing myself to get a good setup but I’m happy I did what I did.
I wouldn't mind seeing what the insides of that POS look like myself
Don’t know much about this type of pump but it seems like it would be harder to blow through than it did!
i think if I tried to take it apart I would destroy too much of the guts to see what’s in it, but it’s out and on the concrete!!
It is a rollervane type pump. Better if you googled it and looked at the way it works.
Edited by RAD
40 minutes ago, Mopar1973Man said:
This is the old Carter pumps.
the stock pickuo tube or drawstraw(?) that is in the fuel tank, what is it made of?
what are the chances of something going awry with the in tank unit that would allow it to suck air? the tank is not completely empty so now would be a good time to remove it and check thing out.
well there you go, got to thinking last night, i have put fuel in it and was able to crank it with that lift pump that was on the engine.  the fuel level has dropped and  and was not able to crank it since last week. thats why i went ahead and too the LP off. i thought there may have been something other than a plastic tube sucking the fuel out of the tank that may have corroded and was sucking air once the fuel level got low enough.
My fuel basket is like the one @Mopar1973Man shows in the picture, with the in tank lift pump. If you have never had that modifacation yours is maybe much different. My pick up is as shown in Mikes picture except that it is 3/8". I figure that is why I see a 4# drop in mine at wot. I personallay dont see that one is alot better than the other except for the size difference. Had I known a wee bit more when I did  mine I would have used 1/2" for my pick up.
 If after you put more fuel in and problem goes away at least you know where the problem lies.
Edited by dripley
