- Replies 56
- Views 17k
Ram Man 02 15 posts
pepsi71ocean 8 posts
CTcummins24V 6 posts
Dynamic 6 posts
It sounds like these guys are way over their skis on this deal. They don't seem to know what they built, or how it works. This is why I rail against "box builders" so openly. When guys just start simp
I finally got my truck back the other week and now have a Goerend valve body, and all is good. I also had someone who does dodge 4 speeds/cummins/diesels all day long do the work. Previous shop did a
I haven't been much help here because, to be honest, I don't have a real good grasp on what exactly it is that you're feeling. It's always tough (often impossible) to offer good advice based on an "it
First let me say Hello to everyone. My name is Jeremiah. I own an 02 that i bought new. currently has 168k. I still love the truck but it has me very frustrated lately and I need some advice. This is going to get long winded but im going to do my best to describe whats going on. It has a Banks big hoss tuner thats 70hp and some 65hp injectors. fairly mild set up and im very happy with how it performs.
several years ago I had torque converter problems. it shuttered in lock up, and you could power through the clutch while it was locked. the more you loaded the engine ( such as in 4x4, or pulling a trailer) the worse the shaking got. i limped it along until it got to a point where i couldnt even use 4x4 in OD because it shook the truck so bad. This shaking could be described like snow or mud packed into the wheels. as soon as i dropped under 45mph and the converter unlocked it went away. I assumed it was the stock junk converter.
finally decided to get the trans rebuilt 3 years ago at 155k and called Goerend but they told me they dont do customer work anymore and would have to go through one of their dealers. so i found the closes one to me and had them do the work. we'll call them "shop A" and all they do is automatic rebuilds and I did all the R&R. they installed a Triple disk converter, shift kit, billet input, ect. dont remember all the little details off the top of my head but i wanted overkill so i never had to pull it again.
fast forward to earlier this year and probably 10k miles later i started having shuttering problems again but it was my only vehicle at the time and couldnt do anything about it so i drove it 2 months like that until i got a new work car. Then i only drove it when needed because it started having delayed engagement problems and the converter would drain back if it sat for more then a week. so i finally did something about it in September. I drove it to "Shop A" so they could drive it and see the problems. they agree that something is wrong and it still under warranty so they will fix it. So i tear the trans out and drop it off.
They told me they found play in the Stator and that was causing all my problems. cut the converter open and everything looked good in there.I asked how the clutches looked and they were like new so they also got reused. They delivered it to me when it was finished and also flushed the lines and coolers since they found some shavings in the pan.
I put it back in and with in 10 miles of driving nicely i could feel that the converter shutter was still there. drove it to work a couple days nicely just to confirm it and its still there. I had a friend look at it and we went for a test drive with his snap on scanner hooked up. I get no codes so as far as the scanner can tell it thinks everything is normal. I also hooked up to a trailer he has that weight maybe 4-5k lbs total and the shaking gets worse. This is something the truck should easily be able to handle but we both agree that something isnt right because the more i load the engine the worse it gets. he just does mechanic work on the weekends and didnt know what i should do next.
Ive done a ton of googling and reading various threads, and In searching my issues online i ran across people moving the engine ground wire out of the harness by the alternator which didnt help me. I checked for AC voltage with my DVOM and got .02v but that was at the battery posts but i realized i need to go back and recheck it at the alternator stud instead. I sanded the block ground, the jumper wire going to the PCM, and the body ground by the passenger battery cable. Ive cleaned the battery cables and even grabbed a can of this copper shield stuff from work which is designed specifically for electric connections to prevent corrosion and promote conductivity. i used it on all the above sanded wires and battery connections with no changes.
I havent let the transmission shop know of my troubles yet because i trust that they are putting out a good product or at least trying to so i assume its on the truck side??? so now i dont know where to go next. I probably should call them at the least and see what they say and ive also been tempted to take it to this mechanic shop by my house and see if they can diagnose the problem.
I posted the picture of the truck because im sure there are others like me that enjoy seeing other peoples trucks. Thank you for the help. I cant wait to see what the responses are!
