- Replies 6
- Views 2k
Mopar1973Man 1 post
dripley 1 post
dave110 1 post
notlimah 1 post
Popular Days
That’s the spot Mike prefers, hence why he took a pic of it! Lol I put mine in the same spot just to avoid the boost bolt up top getting in the way or cracking or somethin.
I made a boost bolt for mine long before I knew of the above location. If I'd have to do it again I'd do like above.
That hollow bolt is just risky either break the bolt torquing or the tubing get broke every time you pull the valve cover or injector lines.
I am getting a 0-60 boost gauge. Is the below location a good location to put my boost gauge feed? Or is the boost bolt a better setup?
