Winterize fuel, high cetane
The fuel I've been picking up finally went to winterized diesel and the cetane really jumped in the last few tanks. Found that you have to retard timing a wee bit to gain the edge again. A lot of people consider the air temp like I did too thinking cold air will take more timing to ignite the fuel. Actually the cetane has more weight that air temperature. Even though my morning run is at about +10°F my IAT is about 62°F. I tried advancing timing found the MPG dropped hard to 17.6 MPG. Now after retarding jumped back to 19.5 MPG.
This follows the same rules that the MPG of the Mopar1973Man High Idle. Just I'm programming a tune to take advantage optimal timing. Still the MPG switch helps for during your warm up mode till the Quadzilla goes into full run mode.
  • Replies 25
  • Views 6.4k
  • I dropped my timing 2.5* a few weeks ago after noticing a drop in MPG's.
  • Interesting. Looking forward to the results
  • I don't recall where I read it, but I did read that fuel that has the Cetane chemically altered doesn't have the BTU change, which does make sense.    I've also read that many places now jus
Good point!! Plus I had a 600 round bale in the back for traction, so I know that hurt some as well.
We all need to drive around with one of them in the back in the winter time :lmao2:
I had to do something so I didn't drive in 4x4 all the time. These thing suck in the snow! Especially with the long bed. But that round roll maybe a huge difference.
I don’t notice much difference unless I have around 1K in the bed.
I need about a ton centered just aft of the rear axle to get to the ideal 50:50.
Yeah, torque can be tricky. My throttle sensitivity is lower than stock for winter and dirt purposes.
