Recommended thermostat opening temp
- Replies 34
- Views 11k
Mopar1973Man 10 posts
pepsi71ocean 7 posts
wil440 6 posts
NIsaacs 3 posts
I replaced mine in September. Printed on the bottom of the thermostat is CALTHERM 190F 3935824 9-99 DOWN so It's a 190°F. I purchased a new thermostat from the Cummins dealer. Part number 3946849,
I can't begin to imagine not being able to get parts easily and have them in less then a week without paying extras just because. You guys in UK are patient ha ha.
It can be a challenge thats for sure, like the water pump... tell tale hole is a little damp so get one on its way, it may never leak or it may puke tomorrow, fan belt.... nothing wrong with it just g
Another thermo question... Just flushed the cooling system today as truck takes a while to warm up, used Cat cooling system flushing liquid but I doubt I'd got enough to do the job properly so I'll have to get more and do it again but it has softened deposits I can see in the rad, backflushed heater core and engine/rad with water after draining the cleaner, took a look at the thermostat which was closed (cold engine) BUT tried to remove it and decided the only way it's coming out is scrap so I left it where it was for now so I can't tell what opening temp is fitted so whats the best to use ? truck is 98.5 2500 4x4 short quad.
I think looking at the colour of the coolant it was volvo earthmover 50/50 which is ok but thats been flushed and refilled with Cat ELC 50/50 I just need a gallon of Cat ELC top up which is not diluted to bring the mix to 50/50.
Also going to get a new water pump as the tell tale looked a little too damp for my liking
