- Replies 19
- Views 5.1k
01_Cummins_4x4 7 posts
gipperkid 4 posts
pepsi71ocean 3 posts
Dieselfuture 2 posts
Flagship buys PCMs/ECMs from salvage yards. They clean up the case and bead blast it to make it look like a reman or new one. Not sure if they program the PCM/ECM or outsource that. We sell about 10 m
The downfall of this is that I will have to return my ECM to stock, which will erase my ABS adjustment for my 35" tires and force my speedo to be off by 10 mph at 60 mph again. I was able
I just installed a brand new PCM from flagship one that they programmed to the VIN of my 99 Dodge Cummins auto trans pickup. At the same time I installed a used 99 Cummins ECM that I got from a friend, but he couldn't remember if that pickup was a manual or auto trans pickup.
There are no codes nor CEL coming up, but at idle when I put it into gear now, it sounds like the motor has a lopey cam in it. If I put it into park or neutral, it idles smooth, and it runs smooth down the road.
Now my pickup will display the WTS as soon as the key is turned on, and I don't have to wait for the WTS light to come on each and every time to get the engine to fire up after it's already been warmed up.
Are the manual and auto trans ECM's programmed differently due to the factory idle speed or fuel mapping?
We reset the timbo apps to see if that would help, but it didn't change anything.
Do the ECM's contain the VIN of the pickup like the PCM, or does it care about the VIN?
Thanks for any help anyone can provide.
Doug
