This problem has me stumped!
- Replies 30
- Views 6.8k
my99ram 9 posts
dripley 6 posts
Mopar1973Man 3 posts
Dieselfuture 2 posts
It's not the fuel boss causing this problem. P1689 no communication between ECM and VP44 The same thing happened to my truck when the VP44 failed just north of Riggens, ID. It was ru
the lift pump going on and off randomly makes me think you have a wiring issue or an ecm that is giving up the ghost.
I chased intermittent Engine shutting off. It was the relay. Cheap fix!! Michael
First a little background.
After my last trip of about 1200 miles I decided to upgrade my lift pump because the old (new) carter was misbehaving (again). I replace the original carter before last years 7000 mile trip, fuel filter also. Worked flawless as far as carters do. Ran about 7-9lbs FP until about 300 miles from home. Pressure went to '0' for about 10 seconds while entering the freeway and then returned to normal. When I got home I changed the fuel filter and then all was well. This year the carter went to '0' again for about a minute or so up in Sandpoint, Idaho and then came back up to 6-9 lbs. Made it back home ok and changed out the carter to a fuel boss.
After changing to the fuel boss I took the truck for a test drive. I went about 1/4 of a mile and while driving about 40mph the engine shut down. I coasted to the side of the road and started the truck back up. Check engine light came on. Fuel boss gives me a constant 17 -19 fuel pressure.
Ok, go to O'reily, read codes P1689, P1690. Crap, never had codes before.
Checked online at other dodge sites (hadn't found this site before ordering the VP, crap) they said VP44 is bad. Crap! I figured I needed a new VP44 because I never had fuel pressure readings above 9lbs with the carter. Mostly between 7-9. Sometimes 3-4.
Replaced VP44.
Truck running again. Happy again. I don't use the truck much around town. Mostly for trips. I have a slide in camper.
Had about 100 miles on the new VP44. Wednesday the 21st. Went to get some lumber for a stair project. On my way home, about 1/4 mile from the store and going 45 mph the truck shuts off again, engine just dies. Coast to the side of the road. Truck won't start. Wait about 5 min. Truck starts and I make it home. I park in the driveway. About 4 hours later I go to start the truck to put it in the garage. It won't start and check engine light is back on. I bought a code reader and it says P1689.
Today I go to see if the truck will start. It starts right up. Starting pressure is about 7 with the carter until the fuel boss kicks in and then 17.
What can I check to get to the bottom of this problem? Would it be something the fuel boss is causing or just coincidence? I have never had any problems with the truck except a bad ABS sensor in the differential and now this stumper.
