- Replies 16
- Views 2.6k
dripley 5 posts
Bgtransport624 5 posts
Marcus2000monster 4 posts
Mopar1973Man 1 post
Popular Days
The lift pump gets its power thru the ECM. The grid heaters get there power straight from the batteries. I am not sure whether the ECM or the PCM commands them to turn on. I think it is the ECM.
All I can say is you need to start reading up as much as you can on these 24 valve vp44 trucks. Lots of things to learn. Do you have any gauges? Need to know your fuel pressure at the minimum. I
The ground mod helps with stray AC voltage the alternator can produce. This can also hurt your electronics. Has nothing to do with DC out put. My AD came with an inline fuse and a relay
I'll start at the top auto to nv5600 swap still has auto ECM
a few months ago I did fuel filter change went to prime filter realized I had no power to lift pump I needed a truck in a hurry as I use this truck for hotshotting so I hot-wired my lift pump straight to fuse block comes on with the key the grid heater has also been intermittent when it does come on it seems to cycle way faster than it usually does
Next day I drove about 80 miles to pick up a load truck was sluggish the entire way got there and then truck did not want to start unhook lift pump fired right up so from what I could tell I had a bad vp44 I also had a weeping head gasket by the time Ipulled it into the garage it was shaking and sputtering very bad I tore it down head was cracked so I picked up a completely remanufactured factory Cummins head from d&j machine Presed in exhaust valve seats brand new dap 50 horsepower injectors remanned vp44 new power steering pump new gearbox set intake valves at .010 exhaust valves at.020 when I was done truck started relatively easy it seems to have a Miss at idle but doesn't seem bad enough to call it a dead cylinder when I drive it down the road it seems to smooth out and run fine but I do feel like it's lacking a littlethe only codes it's throwing are Auto tranny codes because I still have the automatic ECM in it with an nv 5600 the miss that it has is almost unnoticeable at an idle you can just feel it but when you let the clutch out it gets worse and gets shaky along with the miss my intake sounds only to be described is like a helicopter thumping
Please help
I feel like I'm having a ECM issue because both heater grid and lp get there feed from the ECM ¿?????¿?? I think ¿?????¿?? So I'm thinking vp could be getting bad info causing the miss
And is there any way to have a ECM tested other than the dealer
sorry for dumb questions I'm new to the diesel engine any help is appreciated
Edited by Bgtransport624
