Calling Commercial diesel mechanics(air line questions)
- Replies 12
- Views 2.7k
pepsi71ocean 5 posts
dave110 2 posts
KATOOM 1 post
Dieselfuture 1 post
"you guys go to pick up air line fittings and hose for trucks?" locally I have place that fixes hydraulic lines, good supply of fittings. broke down on road once in unfamiliar terri
I have a Parker store down the road from me. I use them for all my fittings. See if there is one near you. http://ph.parker.com/us/en/products
The concern I have is that the Tank placement is under the passenger side on the frame rail. And Up here I'd rather not run water through my pacbrake, solenoids, and tank and possibly other things lik
So I've been wring in my PacBrake into my dodge and i want to install a dryer into the system. But I'm have problems with designing and then where to buy the parts to do this. Does NAPA carry this stuff, or where do you guys go to pick up air line fittings and hose for trucks?
The set up that Pacbrake has may work great in Arizona, but up here in NJ and PA I don't need frozen lines on an exhaust brake.
