Foglight wiring issues
- Replies 44
- Views 13.8k
Marcus2000monster 21 posts
Mopar1973Man 8 posts
IBMobile 7 posts
Dieselfuture 3 posts
dont delete....post your solution or routing of wiring. possibly someone else may need similar info.
Thanks again for those. I feel dumb but I replaced the bulbs and now they work!
Please do tell us what you found. Even the simplists things are not always obvious.
Alright, a lot has happened with the truck since I last commented on here. My truck is a 1998.5 slt Laramie(I have the pull out headlight switch), everything I read online says it comes with foglight wiring. I bought a set of 4 led pods, 2 fog light relays(as my PDC had the slots and 12v power running to them, I used a test light to check for power) I installed the 10amp fuse for the drl lamp spot as it was missing for some reason but was also hot. My trick has a plug in the center underneath the radiator. I went to the salvage yard and found a truck with some foglight wiring but it was 2 prong plug, and I found a truck with a 3 prong plug like mine but just the plug as the wires had been cut. I know I can just run them to the battery and then to a switch, but I want it to be as factory as possible. The 1998 foglight/airbag switch is discontinued so I was going to try and wire my low beam power to the relay which would then send power to the foglights when low beams are on. So my question is, is this 3 prong plug correct or am i SOL? And if it is correct what other fuses/relays do I need to install in PDC or fuse label in cab to send power to fog lights while low beams are on. I know I would have to splice atleast 1 set of wires.
Edited by Waydin_Stewart
