- Replies 10
- Views 2.9k
dripley 3 posts
Dieselfuture 2 posts
Rotax3006 2 posts
pepsi71ocean 1 post
Popular Days
You can get allot on there with air bags. This was about 7,000 lbs here. The D80 in my truck says 11,000lbs but my rear is 3,300 empty. As long as you don't exceed your axle a
Well it's not as bad as it looks, truck did fine. Probably could have put more but was running out of room with topper. I think it's right about 3,000lb didn't even touch overloads but I did have 50 p
Here's my 3500 V8 with 2000kg/4400lb of biomass pellet for my boiler, little top heavy but no problem, not loaded my 2500 too much yet but 2 pallets of those pellets wouldn't fit in the bed anyway.
I know this has been discussed in the past, but I wanted a refreshment on this subject. I need to bring some sheet rock home and wondering where the limit is. From what I read d80 supposed to handle something like 11,000lb so hopefully I don't have to worry about axle housing or bearings failing. Another factor is springs, which I have air bags to help and tires. I would say I can move around 4,000lb driving in town taking it easy. I've had right at 4,000lb of paving blocks in her before and did just fine. The issue now is my truck is a short box and I'm getting 12 feet long sheets of drywall so the weight will shift more back. I made a support bracket that slides in reciver to help the tailgate, it sticks out just passed the gate. I've moved 14 sheets the other day and it seemed fine, today I need to move about 40+ sheets and thinking doing it in one trip. Each sheet is 67lb according to menards. So waight wise should be fine but the way it's spread idk. I've seen 1/2 ton trucks with 4,000lb of gravel and some rental 1/2 ton trucks with drywall that was sticking out a ways making me believe sheets were 12' long and the truck was looking at sky.
So how much weight have you had in box and what are the thoughts. I know a smart one would be make more trips, but I like challenges.
Thanks fellas.
