Fuel Return Tee Bracket Question
This is my first post but I've been a long time lurker and have found tons of information here, so thanks y'all!
I'm currently chasing a fuel leak in my 2001 that has eluded me at every opportunity.
The leak is on the rear of the engine and only occurs after being driven some distance.  Around town it doesn't leak, but every morning after my 17 mile commute to work it leaves a softball to dinner plate size puddle under the truck.
I have replaced the washers on the return banjo on the back of the head and the seals in the fuel return tee.  Upon doing this I noticed that the return tee is just hanging there, the mounting tab isn't bolted to anything.  I can't see enough to tell what it should bolt to.  The factory lift pump is no longer there if that matters.  It was removed when the frame mounted lift pump was installed.  Anyone know what that tab bolts to?
Thanks!
  • Replies 29
  • Views 4.6k
  • Let me go check the thread pitch and stuff. I do remember it being a small diameter and short bolt.   may be an hour or so.
  • That connector tube tool is just a nut that will thread on the tubes after they are removed. Not sure why they include it. They will pop out easily with a screw driver. It wont f them up the steel in
    For noobies... I highly suggest just pulling the injector lines completely off. 1,2,4 in the first group. Then 3, 5, 6 in the second group. Now with that all removed it much easier to get #6 out.
My tab is “L” shaped with a hole in the short length , should bolt to a correspond threaded hole on the head. The hole is hard to see but it is there.
I can see what appears to be a hex shaped standoff with a threaded hole that may be where it mounts but the bolt is missing.  I cann buy a bolt if I knew what size it was.  I just reinstalled the short line from the tee to the head.  Pulled it to check for pinholes.  No luck there.
7/16” long
1.25mm
Check your fuellines where they bolt to the head. A leak there will run off the back of yhe engine. A small leak will take a while to run off the back of the engine.
Dripley
Yesterday I purple powered the the top of the intake and all the injector lines.  There was fuel present along the entire top of the intake, but I couldn't tell where it was coming from.  Now that it's dry and clean I'm going to check it every time I drive it to see if the leak appears.
What's strange is I haven't fooled with any of the fittings in a long time.  I had the injector lines off twice in the past but it's been years.
The nuts that hold the fuel lines to the head do not seal anything. They just apply pressure to the fuel lines and connector tubes. That is where the seal occurs. The oring on the connector tubes provides a seal for the return fuel galleys in the head. If one starts leaking the nut wiil not stop the leak. The threads for the nut are not tapered and will let fuel by if either seal fails.
Do you think that it would be a good idea for me to replace all the connector tube o-rings?  I'm sure it's never been done.
Thanks
Might not be a bad idea along with the injectors if they both have been a long time being replaced. Are you the original owner?
Dripley will do on the connector tube o-rings.  I am not the original owner.  Purchased it in 2011 with 165k on it.
When you talk about the injectors are you saying to replace them also or just the seals?
I recently had Blackstone labs do an oil analysis on it because I thought I was making oil.  I was about a quart high after a change.  The report came back showing no fuel in the oil so it had to have been my mistake filling it up.
Thanks
Just did that one myself.
If you are so sure the connector tubes have never been done then I am thinking neither have the injectors. If I get far enough in to change those orings I am not that far away from doing an injector swap.
Got any idea how many miles are on the injectors?
I'd be almost 100% positive that the injectors are original.  I bought the truck from the original owner and he never mentioned injectors..
My mileage does kind of suck and that may be a factor.
Injectors only last about 100k miles. Even though the injectors still run fine the pop pressure could be really low. Like my stock injectors have 150k miles and they run fine but the pop pressure is below the 293 Bar limit. More like 250-260 IIRC.
Once I get mine running again I would like to watch the video about removing and cleaning injectors.
That does bring up the question for me as what injectors to go with.  I know I would like to do the quadzilla tuner in the near future.  I'm not sure if my signature is showing up but the truck has:
BHAF
MBRP 4" all the way back
Raptor 150
Vulcan Big Line Kit
Edge EZ
ISSPRO Mechanical Fuel pressure
ISSPRO EGT
ISSPRO Boost
Revmax full billet trans
2015 17" wheels
285/75-17 All Terrains
