- Replies 29
- Views 3.2k
Manimalmother 14 posts
dripley 6 posts
Mopar1973Man 5 posts
RAD 4 posts
Popular Days
Let me go check the thread pitch and stuff. I do remember it being a small diameter and short bolt. may be an hour or so.
That connector tube tool is just a nut that will thread on the tubes after they are removed. Not sure why they include it. They will pop out easily with a screw driver. It wont f them up the steel in
For noobies... I highly suggest just pulling the injector lines completely off. 1,2,4 in the first group. Then 3, 5, 6 in the second group. Now with that all removed it much easier to get #6 out.
This is my first post but I've been a long time lurker and have found tons of information here, so thanks y'all!
I'm currently chasing a fuel leak in my 2001 that has eluded me at every opportunity.
The leak is on the rear of the engine and only occurs after being driven some distance. Around town it doesn't leak, but every morning after my 17 mile commute to work it leaves a softball to dinner plate size puddle under the truck.
I have replaced the washers on the return banjo on the back of the head and the seals in the fuel return tee. Upon doing this I noticed that the return tee is just hanging there, the mounting tab isn't bolted to anything. I can't see enough to tell what it should bolt to. The factory lift pump is no longer there if that matters. It was removed when the frame mounted lift pump was installed. Anyone know what that tab bolts to?
Thanks!
