- Replies 33
- Views 5.6k
Stanley 11 posts
Dieselfuture 6 posts
trreed 6 posts
Mopar1973Man 3 posts
The noise you have described with an idling engine and transmission in neutral is a normal sound for a dual disc clutch and a warmed up transmission. The pulses from an idling long stroke diesel engi
@Stanley thanks, man.
Yes, I read the forum mentioned above and I think that wiould be a good bet and a safe one. I have had the trans pulled for awhile now, I know what clutch I had in it. I am just looking for ad
So Im looking for a new clutch I like working with DAP, so I emailed them this:
Also need to figure out which clutch I need to get.
When I bought the truck I was “told” it had a dragon flow vp44, 6x18’s, .093 lines and tubes, ham cam, springs, and 64/71/14 turbo and all the supporting mods and more. I did verify I have a valair competition dual disk (sintered iron) for pulling, I have taken all the electronics off of it and the only thing I havent verified is if the vp is infact a dragon flow… It does still have a ton of power so it might have it. I don’t plan on racing or pulling with this truck just a occasional driver or weekend truck and pulling a gooseneck with a skidsteer. I would guess the clutch would have to hold at least 600hp idk… and dual disk for towing. What do you think?
What do you guys think? He put this on the quote:
Valair Dual Disc Performance Replacement Clutch (Ceramic) 650HP NMU70NV45DDSN | 1989-2003 Dodge 5.9L Cummins With NV4500 or Getrag 5SPD
SKU: VAL-NMU70NV45DDSN
And yes I know it says for a nv4500... I need one for a nv5600... however...
I really dont have a good estimate of what I might be close to on power. I dont want to get a new one and slip it cause I have to many ponies...
