- Replies 13
- Views 3k
								Ronniemx3 5 posts
								Mopar1973Man 3 posts
								Me78569 2 posts
								Marcus2000monster 2 posts
Popular Days
								I would byuy from DAP as they are the same owner as quadzilla.
								4K box has different hardware and software. It basically has timing tables to 4k RPM and rev limiter to match. Where the standard Quadzilla goes to 3.2k for timing (typically) and rev limiter to 3.7k.
								It is a PV2 screen, still old and unsupported. You can update to V2 tuning if you get the iquad dongle. the 4K a bit of a bummer. yes it can work, yes you can set rpm limit lower, but
Well i managed to buy a quadzilla adrenaline... I think its a v1 can I still make tunes on a v1? Is It worth buying the iquad adapter? And anything i should know about when i first set it up on my truck?? I saved alot of money compared to buying new and import tax etc to the UK.. any advice is much appreciated
Edited by Ronniemx3
Forgot to add images
