Cab corners.
Trying to find some cab corners for my quad cab. I see extend cab, quad cab, and standard cab. What do I need to get for my quad cab? Will the extended cab work?
  • Replies 10
  • Views 2.5k
I would assume a "Quad Cab" would required a "Quad Cab Cab Corners"
An extended cab won't work because there is a no read quad door.
Standard Cab wouldn't work either being the rear of the main door is the cab corner.
They all look so stinking close! And they don't give measurements. Maybe I can find both sides. Found passenger side but not drivers.
 I think one has the extended cab that is solid, without the half doors in the rear, is that right?
The doors are diferent from one to other, ones are square and others are round.
I also need some cab corners. Waiting on some progress pictures :drool:
Getting the cab completely done at the end of February. Deer decided to ram my drivers side front fender door and bed. Not a fun morning however it will be better than ever after it's all said and done.
Edited by Unreal Summit
