Turbo Install
So last week I installed a set of 7x10 injectors.  I am thoroughly impressed with them but they make me nervous with my stock HY35.  I'm traveling for work right now and happened on a good deal on an HX35 off another 01.  I scooped it up because of the price.  No shaft play and looks pretty good.  From what I've read this should be a direct swap for the HY.  Is there anything else I may need?  I'm planning on hauling my fifth wheel back home Friday and may try to install in the hotel parking deck.  I'm sure they will love that!  The HX should have lower EGT's than the HY correct?
Thanks!
  • Replies 65
  • Views 12.3k
  • Manimalmother
    Manimalmother
    Gotcha.  I'll put that on my list.  By the way, I caught my pregnant wife on my security camera.  She stole my hoodie!
  • Manimalmother
    Manimalmother
    Well I got the housings back this evening.  The exhaust side is ceramic coated silver and the compressor housing is powder coated "titanium pearlcoat".  He then masked and did "holset" in gold.  We'll
  • dieselautopower
    dieselautopower
    Correct,  It will help top end power.  Low end spool up will be slightly inhibited as you will lose some of the pulsing of the twin volute.   Reducing back pressure is important.  1.2psi bac
25 minutes ago, dieselautopower said:
he351 is 60mm, same as hxsuper40
27 minutes ago, trreed said:
HE341 should work, it's the HE351 that's 58mm.
HE351 is just about the same as my HX35/40 Hybrid.
I always thought the 341 was the same specs as the HY35, just with a 3rd gen style cover.
  • 4 months later...
Digging up my old Post because I never finished it.
I installed the new compressor wheel but it turns out the shaft was also bent.
Ordered a new shaft and put it all together and it runs great.  Definitely dropped my EGT's.
The other day I was browsing Amazon warehouse deals and bought a Wicked Wheel 2 for 30 bucks!  I know that these things don't do much for our trucks but I bought it because of how cheap it was.  It had been returned by someone but never installed.
I installed it this morning and cannot tell any difference at all.  If anything it spools slightly slower than it did before.  Oh well it was cheap!
