fighting through my scenario............
I am at a crossroads, just moved to California and it is time to deal with Smog and licensing the '01....  truck has 350k miles on it, trans synchros are tired in 3rd and 4th, door hinges are shot, leaks oil (either tappet cover or the vacuum pump)..  bed is in rough shape, little rust in the lower door skins...   So thinking, if I was going to make a change, now would be a good time.  So if I did make a change my wife would like me to get a non dually (we don't tow anything too large anymore so that is no issue) maybe a short bed would fit in the garage.   Maybe a 3rd gen would have 4 real doors... oops did I say 3rd gen????  So dilemna that could use some wisdom.....  are there big advantages to a 3rd gen over a 2nd gen?  I think '05 they started to make some real power....  I may not, now that I am in Cali, even really worry about 4x4 (my wife has a very capable AWD SUV)
Ok, so 2nd gen vs 3rd gen....  obviously we all love 2nd gens here.  (ever try to find a clean used one that isn't priced out of this world?).  But I rely on regularly and trust this group to shed wisdom from both sides of the aisle (unlike our current landscape of professional politicians :-) )
I look forward to hearing good and bad about both.
Thank you in advance!
**EDIT** I almost forgot... 1997 and older is smog exempt in California, so feel free to include this in the discussion..
Brian
Edited by portlandareae28
at my age how could you possible remember everything the first time?
  • Replies 54
  • Views 9.5k
  • That's the picture they show you when the Viagra lats longer than 4 hours
  • Is it true that in Oregon if you don't drive your truck every day then moss will grow on its north side.
  • portlandareae28
    portlandareae28
    California is not bad, weather is good, people are good, its very nice here.  Its just not as green as the leadership here would like to portray it is.  Work moved me here and while this is probably n
If pre 97 is smog exempt why not a 96 12 valve? Great truck can make power and beSt of all smog exempt! And reliable as well. Just my 2 cents.
I am not opposed to this, just far and few between for a nice one here.
Don’t be afraid to drive a fair distance to get a clean one. It will be worth it. Find one out here near western Montana and I’ll haul it out for ya!
https://sfbay.craigslist.org/nby/cto/d/windsor-clean-1995-dodge-12v-cummins/6799842090.html
herea a nice truck.
herea a nice truck.
I guess 12v are still made of gold too!!!
I am not opposed to keeping my truck.  If I keep it it will get the repairs taken care of, and likely 3rd gen brakes and 4th gen steering.  Just trying to figure out if a different direction might not make more sense.  All used trucks will need something all the time.
https://sfbay.craigslist.org/nby/cto/d/monte-rio-1997-dodge-ramx4-crewcab/6800515273.html
hoowah
hoowah
I wouldn't be interested with that many mods. Frame extended and K&N Filter? That a sure stay away sign to me. Try finding  untouched and original. I had to pay 16 k for a nice 01. On the other hand, It is always least expensive to fix what you have if not too far gone.
That crew cab looks scary..  bed doesn't even seem to sit anywhere close.  THere is a 2001 local to me quad cab short bed 2wd I am just not sure on the 2wd yet..  but its really just mental as I have never put the dually in 4x4 in the 3+ years I have owned it.  I will just keep on plugging away at the little projects on my current truck, as I agree always cheaper to keep.
I like that a lot of after market items are better than oem as long as there isn't so much that it you have to work late every night to get it done. California has way better weather for working on trucks. Oregon isn't right now.
I guess if there is something good about diesel truck ownership in California this is it.  Maybe I should get a 6.2 to take full advantage of this situation :-)
No no :nono: You make your truck the nicest one around. Remember 4x4's are worth more too even in snowless mudless country.
Yes you have to back in one day and pull in forward the next
. It turns out that most 6.2's have monster moss and don't know how Dripley ended up in virginia on his migration route. Man... he's way off .
Chickens don't migrate :doh:. They just cross the road. To this day nobody knows why though.
                           The answer to that age old question.
I knew you had that one in your arsenal. Was hoping you'd take the hint :lol:
3 hours ago, dripley said:
And @IBMobile wins the coveted plastick chicken award.
      I thank the Chicken Man for the recognition and will display this wonderful symbol of achievement at a prominent place within my home.
Edited by IBMobile
I had a 05 3500 quad cab short box 2wd. with a NV5600 and it was a good truck. Only thing I did was routine maintenance and rebuild the front end. Ujoints too. Its still going good with 260k on it. Injectors are always a worries but check for blow-by first and foremost. I could get 25mpg. empty and had plenty of power. Was stock and had no issues pulling 20k. I guess it depends on if you want full 4 door or even want to mess with a newer 6.7.
Just my :2cents:
