Airdog problems... again...
- Replies 37
- Views 8k
hex0rz 10 posts
Mopar1973Man 9 posts
dripley 8 posts
Haggar 4 posts
There should be battery voltage at both sides of the fuse and terminal #30 of the relay. ECM voltage at terminal #86 when ignition switch is first turned on (5sec) and when starter motor is engaged
The schematic is fantastic reference. NOTE - you can pull the relay from the Relay block (assuming it is plugged into a relay block) and put a jumper wire from 87 to 30 - and see if the l
hex, Chicken man is suggesting you check what is really happening at the ECM, not right at the plug where the pump plugs in. How are you checking it? Terminal 1 to bod
With the recent snow storm I was pummeled with, I had to utilize the truck today to get to work. Unfortunately, the lift pump wasn't giving me a pre start prime. Even cranked over and running, the lift pump is still not giving pressure.
I checked the fuse, it's good. I swapped the relay out with a different one. Nothing. I checked voltage at fuse and got nothing.
Any ideas? Pump dead? Some other electrical issue?
