Quick Pic needed
I need a quick pic of how the heater core hoses are routed. Putting in new hose in atm and cant find pics of how its supposed to be routed...
  • Replies 17
  • Views 3.6k
  • Rubber hose on Exhaust turbo total fail!!!  You asked what we thought.  Bone yard or dodge dealer and get the correct part.   Michael
    Small chunk of hose and two squeeze clamps. Then steel tube.
Mainly the lower one (longer section)
Is it routed up and around or side of fender or by the block...
What? Never routed like that. You might want to snap a picture.
Check this out..
How is the lower one routed?
I hope the video shows what I'm needing.
@Mopar1973Man does this help?
Ummm... Someone's nasty idea of plumbing... It suppose to be a steel pipe from the fitting in the front to just behind the turbo. Then 2 short hoses from the fittings to the firewall. There is nothing I know of for coolant at the front like what you got... :think:
You must be missing that tube Mike is talking about. When I had my turbo replaced I took that tube off and cleaned it then put few coats of paint on it, as it was getting rusty. Maybe yours went bad and po threw it out. You can make something out of brass tube, elbows and put some inline shut off valves to isolate heater core, like some do.
Michael
Well the extra hose just laying there was just me messing as round. I wouldn't be putting it near enough to get hot lol...
So I guess what I  was after is there is supposed to be a metal pipe running back... yea I never had one, go figure. I guess I'll plum one up going straight back then go to hose from there. My father in law might have an extra one from his truck, I'll check that too.
I guess I could just 90* over and around the oil filter? Can someone post a pic of this area so I can see how its routed factory?
Ahh... ok, makes sense now.
Is it a hard connection on the lower or is it a hose (butt connector) just wanna make sure PO didnt swap it out for a barbed fitting or something different. This helps alot, thanks!
