- Replies 22
- Views 5.8k
Mopar1973Man 9 posts
Rotket 7 posts
Dieselfuture 4 posts
dripley 1 post
@Rotket for sure go after the miss.. you can also do a leak down test since you are going to have the injectors out. Pull each piston up on its stroke with all the valves closed on the cylinder. And a
Same here at 355k miles and the head gasket leak.
No. Because both valves are closed. So there is only pressure in the cylinder. No pressure in the intake manifold or the exhaust manifold. Pull the head. Then inspect the cylinder
I developed this miss over the winter and blowby pulsating out of the oil cap. There's also blowby floating by the firewall but that could be coming from the breather.
I don't think i have a vacumm leak because my defrost works. Can bad injectors cause blowby?
Here's a video, sorry for the wind noise.
Sorry I dont know why my sigs not showing up.
154000 mile 6 speed, with edge comp and 5 inch exhaust. Mostly stock truck.
