- Replies 19
- Views 6k
cummins59diesel 7 posts
Me78569 6 posts
kzimmer 2 posts
trreed 2 posts
Popular Days
Yep it is bridged right. The newer flashes are much smoother handoff of fueling. However I would want to fix the map not reading until higher psi. I would get an oem sensor fr
likely has to do with the sharp drop in fueling that happens at 1000rpm, going from stock down to your 0 psi setting.
To start off with, I have a 2002 Cummins 6 speed. I've done a few modifications to it, such as 200 hp injectors and compound turbos. I have a 62 over a s475. I've been running the quadzilla for about a year now and have really loved it. I had a edge juice with attitude before and it is almost night and day difference between the two. However, I've been experiencing some bucking issues. I've tried adjusting different settings and just can't seem to get rid of it. It tends to happen in 4th gear and low rpms such as 1000 to 1200 rpm range. It also only does it on acceleration. When it starts doing it, I just back out of the throttle till it stops and then can get right back into it and its fine. I messaged Quadzilla about it and they were saying that it is just because it is too high of a gear and engine load that is causing it. But I never had the issue before with the edge or even stock. I would think it should be able to accelerate smoothly regardless of engine load. Anyways, just wondering if anyone else has had similar problems or if they know how to resolve it. Thank you in advance!
Tried downloading my tune but it didn't work
Daily Driving Tune:
Power Levels - 6
RPM Limit - 3200
Fuel Stretch - 1500
TPS Max - 100%
TPS Min - 0%
Min Pump Tap Fueling Percentage - 3%
Low Boost Scale - 10 PSI
Boost Scaling - 40 PSI
Max Load Timing Offset - 2.0
Low PSI Timing Reduct - 2.0
Timing Reduct Scaling - 100%
Light Throttle Timing Adv - 2.0
Light Throttle Load Limit - 30%
Timing - 16, 18, 23, 25, 26
