Gallon Trip reset every power cycle
I've seen this mentioned in other threads, but has anyone looked into it yet? It seems ever key-on the gallon trip is reset no matter what the toggle in the iQuad app is. I tried reinstalling the app from the PlayStore, and I have the adjustment set at 140%. It was set at 135% as well and was doing it. When I first had the feature it was all default and wasn't resetting. I actually had a hard time figuring out how to reset it at first.
I just went for a drive and did a pretty quick key off while I was going down the road, and as soon as the key was back on the gallons were reset back to 0. iQuad app didn't go through it's long connection setup either.
Anything else I can try? Want to borrow my unit to check? Turbo countdown works fine when I remove my key so I don't think it's a power issue.
  • Replies 31
  • Views 7.9k
  • Quadzilla Power
    Quadzilla Power
    This seems like its the same issue that's keeping me from releasing the average MPG gauge. When you set the value for the offset, sometimes, it wants to toggle it off then back on which causes it to r
  • I am still working on this.  I think I may have finished last night.   The issue was 2 fold.  the gallon trip was never designed by myself to save on key off.  took a bit of a rewrite to mak
  • Any news on this?
Yep I found the issue,  I went back in to take another look and felt alittle stupid.   hard to spot but simple mistake.   @Quadzilla Marco has the info to fix and rebuild.
I am not sure what all has been put in place for long term mpg averages, but I see issues with that code as well, but I dont see a sensor for that yet so I am guessing it was never finished.
Edited by Me78569
@Me78569 was there a firmware update released for the Quadzilla?
Yeah the MPG code wasn't finished it was kind of left hanging. The only thing it will report is the Gallons consumed. For the normal 98.5 to 2002 Dodge profile.
Dunno i cant build a flash anymore.  Quad has the source change.
The issue was 2 fold.  the gallon trip was never designed by myself to save on key off.  took a bit of a rewrite to make that logic work.
  • 2 months later...
On 5/2/2019 at 9:26 AM, Dieselfuture said:
Idk then, mine seem to work fine with older version I posted
OK I feel like usual, you all talking gallon trip and I was thinking total gallon used, so yeah ignore everything I said.
Glad Nick got it all figured out, I may or may not update, don't really care for gallon trip option for some reason.
  • 3 months later...
Any news on this?
On 3/16/2020 at 1:10 PM, beren said:
Any news on this?
Not sure... I'm going to look into this and see if it continues myself I gave up a while back on the gallon display.
