spacer.pngSince I got the dodge in the garage for it’s annual tune up I thought I would tackle the front drivers seat project. I was in desperate need of a new cushion and cover. I found a place on eBay that had the factory original copy of the covers, along with the new foam.
I wish I could post links but my computer is having issues with that. The place is called autochampoftexas, Therr prices were comparable and when you place your order they have you send in your vin # and trim code # to make sure you get the right pattern and color, anyway it matched my original perfect.
4EB4A0C4-1F53-42D9-BB76-4D5BF186C637.jpegAnd the new
Edited by 01cummins4ever
  • Replies 24
  • Views 4.6k
  • 01cummins4ever
    01cummins4ever
    187.00 for the skin and 106.00 for the foam, both claim to be USA made and seem to be of good quality,  It was a tight fit stretching the skin over the foam and took some time and patience
  • Just make sure they not from North Carolina somewhere..... I hear they got fleas.
4-10mm screws underneath holding the seat frame/cushion down, easy.
Edited by CTcummins24V
I got to get in there to see if the seat heater is an easy fix. I understand sometimes its a simple burnt wire. My seat is sagged but comfortable.
Never knew it was so simple!  My wire is all busted so I put a piece of 3/8 plywood in there for now. It’s hard but I feel like I’m setting on top of the world.
13 hours ago, Marcus2000monster said:
I can’t wait to do this. Mine leans to the left badly. Will I need the new leather piece to because mine is perfectly fine. Just saggy.
I would just reuse the leather if it’s still in good shape
