5 Speed Clutch Pedal Travel
- Replies 21
- Views 9.1k
Greenlee 8 posts
dripley 5 posts
Mopar1973Man 3 posts
Dieselfuture 3 posts
I don't believe they are adjustable in stock hydros. Aftermarket may be different. I have to pretty well put my clutch pedal to the floor on my 5 speed. Was that way with the old clutch and the new on
I see reading down the page that it is not adjustable, good to know. I plan on driving it since it doesn't make sense at my age and with my medical history to invest in anything else. I'll get the ped
I know this question has been asked in the past but I couldn't find the info. I have a 1999 Dodge Ram Cummins 2500 5 speed and to engage gears the pedal has to be pressed into the floorboard carpet. I have tried to sell this truck without any takers. There is over $10,000 in parts and labor above the price I paid for it. I have about $4K and my brother when he owned it put another $6k in it. Some of the costs in parts was not needed at all, Turbo rebuilt by Mid-West Turbo when nothing was wrong with it, Fluidamper added, Hi-Torque starter, Ceramic disc brakes and so on when good stock parts are more than good enough for a 20 year old ride. My brother is not a diesel mechanic but does work on his vehicles. He was trying to establish reliability because he was on the road all the time working. So now I took it back to try and sell. I refuse to just give it away for tree trimming and yard work, some offers are crazy.
I plan on keeping it and driving it. Problem is I wear leg braces so my ankle does not flex. I find my foot has to be turned sideways to press down the clutch pedal and that causes my toe to press on the brake at times when shifting. I'm going to get a second clutch pedal, bend it, form it around the pedal in the truck to sit at the same level or angle up a little depending on how it does pushed all the way down and the flatness of the floor board where it will hit. This would give me some more area and keep the toe of my shoes away from the brake pedal. I don't know if this is normal or not but the pedal has to be on the floorboard to put it in gear and shift gears. There are no leaks, fluid looks great but the travel to the floorboard seems a little too much. I know there is no adjustment but what else could be going on to cause this? I hate to think the clutch or pressure-plate is worn out but that's where I'm heading. It would make sense that it's the reason for the excessive pedal travel. I hate to think that another dime has to be spent on this Dodge being so far in the hole already. If it is then point me in the direction for a new clutch, pressure-plate, etc. I hope I can make it all work. Thanks
