2001 Auto Trans Fluid Change or Flush
- Replies 9
- Views 2.3k
Popular Days
If I didn't have any idea how many miles were on the fluid, I'd do a flush. Regular fluid changes without a flush are fine too, but keep in mind you are only getting half the fluid (estimated), so the
Every 30,000 miles for fluid and filter and adjust the bands, but I probably won't always adjust the bands unless they need it. Change the fluid ASAP if you get it too hot and burn it.
Done that method a time or two for others...
Hi All, I've got 3,000 miles on the truck I bought used last August. I was replacing the reverse light switch and spilled quite a bit of fluid and it was dark. So I was thinking time to get the fluid changed and the bands adjusted. So my question is Change or Flush??
TIA
Michael
