HORRIBLE HORRENDOUS mileage
- Replies 56
- Views 8.5k
Jesniccad 23 posts
Mopar1973Man 14 posts
dripley 6 posts
Me78569 4 posts
I think they're full of it, there is ho, so and some industrial stuff, if it runs good I wouldn't change pump. Have you checked for boost leaks yet, the entire system.
My truck with the same size tires as you, 265 75 16, turns 2000 rpm at 70 mph. Several others here have quoted the same rpm on there 265's. Are sure about your tire size? Big tires eat fuel. 1700 at 7
you should reinstall your injectors, if it doesn't start without ether then you have issues with your fuel lines at some place. Could be the return, it could be the cross overs, or conne
I have a 2000 Dodge Cummins three-quarter ton long box has an air dog fuel system brand new RV 275 Bosch injectors new cold air intake valve lash recently set all new fuel filters cleaned map sensor missing muffler and tailpipe from exhaust running 265 7516 No matter if I’m pulling a load or completely empty I average between 10 and 12 miles per gallon 90% highway miles . I have not had it into the shop
