Injector install questions
- Replies 62
- Views 13.7k
Ravewolf 18 posts
dripley 17 posts
Mopar1973Man 9 posts
WiscoRedkneck 6 posts
Just wanted to give you all a quick update on my truck. Got the new injectors from WiscoRedkneck, and they worked like a charm. Truck runs alot better also. Down on power obviously because of st
Btw some may call me a hoarder for taking their old junk but hey the right "thing" that is someone's junk can usually be repurposed or rebuilt and maybe save my butt or someone else's so cheers to bei
Did you get it to start? Mine took a lot of convincing to get going again open one set of three lines crankit until fuel comes out close those open next 3 crank close after fuel present I left engine
So I've been doing research lately, and had a sneaking suspicion that I had a leak somewhere after my injection pump. After looking hard, sure enough #5 fuel line was slightly wet. I said screw it and ordered an injection seal kit from thoroughbred (I think), and while I was at it I broke all the injectors down, soaked them in naptha, cleaned them more with b12 chemtool, then reassembled according to spec.
With the new washers on, I've popped all them in by hand, set the crossover tubes in by hand, and now I'm about to torque the injector hold down clamps. The injectors are sitting higher than normal, is that normal? I figure the new copper washers haven't been seated yet, so they're up a bit higher, but is it OK to crank down those tiny 8mm bolts to seat them?
Edited by Ravewolf
