- Replies 61
- Views 10.8k
OlPurp98 24 posts
Mopar1973Man 19 posts
Dieselfuture 9 posts
kzimmer 5 posts
After the reflash and install of your corrected tunes the truck runs like a dream not smokey and gets up and goes. Huge thanks to @Mopar1973Man @Dieselfuture @Me78569 and @kzimmerfor helping get all t
That would be my suggestion also, ^^^^ Next step would be injectors
I would run the corrected one, your timing was pretty low. For how easy it is, you could run both to start learning how the differences affect how the truck runs.
So this has been an on going issue for quite some time and have hit a road block, under heavy engine load ONLY with tuner turned up it will spit/sputter best way I can explain it is it sounds like I'm bouncing rev limiter, within the last 8k miles I put on a fass pump new vp44 and a revmax trans ( trans was slipping and thought that was the problem spitting and sputtering at 2700 rpms) now she spits and sputters at all different times based on current speed engine load tps and level of tune. I've checked fuel pressure 17 at idle /14 at WOT /, less than .075v of ac noise in alt. Have a p1693 in the pcm that stays after cleared and p1475 witch has not come back yet. tps seems to be right on the money crank signal seems good on my Solus ultra never drops off.. but the B+ voltage on the VP averages 12.1v and will spike to ecm v randomly when ecm v is 13.8-14.1 is this normal or is this the whole problem do I have a ecm on the way out the door? Did I get a **** vp? Any help would be nice
Edited by OlPurp98
Post pic
