Transmission hangs in second
- Replies 31
- Views 6.6k
Why did you replace the governor solenoid housing? EDIT: Never mind, I reread your post. For what it's worth, that modification is completely unnecessary and actually does nothing. As a ma
I finally have had time to work on this problem. First thing was to flush the transmission due to the trans temp going over 250°F and the fluid was dark in color. This was accomplished
The first suspect in any problem with gear selection in the first 3 gears would be the transducer and/or possibly the governor pressure solenoid. If I had to throw parts at that problem, those would b
I drove the truck for the first time in 4 weeks and started getting a no 2-3 up shift condition. It will up shift when backing off the accelerator. All the other shift points are at the proper speed/throttle position.
The transmission speed sensor was replaced 8/8/18 (107,893mi) due to no 1-2 up shift but would start off in 3ed if transmission relay was pulled.
Transmission was serviced with front and rear band adjustment 9/1/18 (108,024) then a 1,000mi trip in October pulling the 5er with no problems.
The transmission now has 109,362mi. I'm thinking it may be the governor pressure sensor and solenoid. They were replaced about 45k mile ago.
Has anyone else seen a problem like this? What say you @Dynamic?
Edited by IBMobile
