Quadzilla Help!! No Boost or Power
- Replies 43
- Views 13k
CBond 17 posts
Mopar1973Man 15 posts
Me78569 6 posts
dripley 2 posts
Sounds like your map sensor is bunk. If you only ever see 0 psi then you either haven't hooked up the wiring right or the sensor is trash. The edge defaults to 10 psi if the
Mine actually turned out to be the sensor. I bought a Standard Motor brand from Orielly's for $100. The other parts houses wanted near $200 for them. I thought Cummins was near that price too. I also
the dbrIII doesn't have to be used, just read the article and test with a multimeter. Check the map setting inside the box for a late year truck
Hey all. Im new here but have been on Cummins Forum and all that. I took off my Edge Juice w/ Attitude and installed my quadzilla last night and was able to take for a spin today.
Truck has no power going down freeway or anything, I can from 20% throttle to 100% and the truck will not move. Struggles up hills and I have never seen the boost gauge move. I think I have a data log from drive home so I will attach it. I also threw a code but when I do the ignition check it is p1693. The last thing is that my fuel pressure goes from 26 to 5 and anywhere in between no matter what. Also did this with the edge but it never turned out to be an issue and haven't got around to see if fass has any answers or not.
Would be great to fix this today somehow. Thanks for the help!
