Truck randomly dies HELP!
Hey there guys new to the site seeking some help. So truck runs and drives but will randomly die or stumble and pick back up it has a brand new air dog lift pump in it and the VP44 is a year old when it does sometimes shuts off or resets the radio, bad ECM? This is on a 98.5
  • Replies 41
  • Views 8.6k
  • Dieselfuture
    Dieselfuture
    @dripley want some, or you're just going to watch me choke on it again
  • hdpwipmonkey
    hdpwipmonkey
    The radio shutting off and/or resetting sounds like an interesting clue...   Losing power somewhere for some reason.
  • To be honest I dont know. Theres a block with I think 3 bolted on them. I'd assume positive.    My truck would die driving down the rd. Coast to a stop then start back up like nothing happen
I've seen this happen quite a bit. The fuse age and the fuse strip oxidizes. Then get weak and cracks. I've seen a starter solenoid fuse crack that would let a guy crank for about 5 seconds and quit. Wait 10 to 15 minutes and it will crank again. I've had the same thing happen on my truck too. I've seen even the smaller ATC fuses do this too. Easy part for those is run the truck till it fails then grab your test light and go around all the fuses on the test point looking for one that is hot on one side and dead on the other. Short time later it will be hot again.
The big square fuses you need to pop the clear cover off and look closely with a magnify glass or carefully with a small tool push on the fuse element looking for separation of the fuse link. Just be careful the fuse won't take much force.
I just tried swapping it with the big black A/C fuse and it still fell on its face I’m not sure where to start looking any more?
Edited by smitty 1833
Did you check those connections below battery.
They have rubber boots over them.
Are these grounds or positives you're talking about
My truck would die driving down the rd. Coast to a stop then start back up like nothing happened.  Turned out just loose nuts on the connections.  Tightened them and truck hasn't died like that in 5 or so years
The only thing I can figure out there is the PDC fuse number 1 (50 Amp) fuse powers the fuse block in the dash. That has the IOD fuse 12 in the dash. Look back at the diagrams.
The only thing else I can think of is a bad ignition switch why it randomly cuts out. :shrug:
My truck would die driving down the rd. Coast to a stop then start back up like nothing happened.  Turned out just loose nits on the connections.  Tight end them and truck hasn't died like that in 5 or so years.
All lights would shut off like all power was cut. I'm sure radio we could reset to.
Your radio comment is the one reason I replied. I'd check the connections then check ignition.  If you cant fix it I'll only charge a small fee to remove it from your property
Kind of doubt grid heaters will make it stall or cut out.
Bad positive lead from the driver side battery to the PDC would cut power completely.
If that's what those are it caused mine to randamnly die.
I did check this grounds under the drivers battery the terminals themselves are tight but where it mounts to the wheel well was a little loose I also plan on getting a new fuel system relay fuse and I reckon I could get that bigger 50 amp one as well and cross my fingers I also read I could crack injectors lines 1&3 while cranking the truck if it spirt fuel out the VP44 is good if not than the VP44 could be the culprit but I always vp either or good are dead I didn’t know there’s an in between with em just doing the process of elimination but I strongly believe it’s something electrical
Where does the power for the ECM come from? It looks like it might be loosing power briefly, hence the WTS light coming on and off like start up on a warm engine.  ????
That’s a good question I haven’t tried to fully trace it but I know it isn’t the ECM put a good one in it and does the same thing it’s definitely electrical just gotta keep tracking it down
I'm curious now about the block I'm going to pull leads off. Prett sure one is to ignition power or ecm.
I'll trial and error just for curious sake and see if one pulled causes it not to start
My truck 90% of the time wont trip a service engine light it will store codes
 Codes I have been unable to reset with both a updated snapon diagnostic tool and mac. I even did some voodoo touching positive cable to negative and negative to positive aswell leaving truck alone for a few days batteries unhooked.  Codes will not go away.
Apps didnt even trip a dash light
Edited by Evan
So I just replaced the fuel system relay the truck did fall on its face BUT the relay is warm to the touch is supposed to be warm? How much colts should it read when pulling it testing it the ignition run, and both engine control fuses get power as well as the fuel system relay but it’s warm
Warm parts means weak connection. Warm relays should be replaced. Warm fuses should look into contacts and replacement of the fuse.
I just put that relay in there too but hey it’s a lead on the right direction but still not 100% where to start looking
10 hours ago, Dieselfuture said:
:popcorn::popcorn::popcorn: @dripley want some, or you're just going to watch me choke on it again :lmao:
Butter it up. Helps it slide down.
